Looking to run 245/40/17 on 17x8 +40
maestromaestro
Man I'd love to do that one day but it seems like such a hassle.
Not really. Drill the fronts and for the rears, you can use a Timken hub. Not that I actually did it myself. At some point, I decided to go balls out on the mods - so, BC2 c/o, WW BBKs on all 4 corners, lowered, and 4x100. Gives more options for the wheels - but I'm out of the 15" market with that, and there are a lot of options for that size.
Yeah a 245/40 isn’t far from a 215/45-17 on their respective widths, but I think it’s just gonna be too much without some type of modification. I’m ruling it out
Agreed. With some measurements taken on the FiST, the graphic can be adjusted to match; and the link posted. That way we have a more precise representation of what room is available when compared to OEM.
maestromaestro
The difference between 215 and 245 is colossal, when it comes to dimensions. That's the whole crux of the matter. And, some would tell you that even the same nominal size varies considerably from a manufacturer to manufacturer.
Jerickson88
Jerickson88
Thread Starter #27
I was talking about the OD
Jerickson88
Jerickson88
Thread Starter #29
Yea, OK. About 150 mils, based on the calculator.
A 215/45-17 on a 7” whee should be about the same as a 245/40-17 on a 8”, outside diameter. Yes?
.1” difference in outer diameter.
maestromaestro
According to the tire calculator, these should be nearly identical. The calculator doesn't take into account stretching of the tire, I believe.
jeffreylyon
It took me a long afternoon. I didn't even need to press the hubs off the knuckles.
Ditto.... And expensive
I think that I paid < $100 for the jig 4 years ago and I just used it yesterday to drill a fresh set of rear rotors.
#33
Thoughts are 245s are wayyyyy too wide! I doubt you could even turn the front wheels properly without hitting all kinds of stuff. I would love to see what it looks like though.
maestromaestro
#35
Well, there are these....
And, yeah, wrong side... I ended up with 3 rights and 1 left.
#36
^^^245/35s??
Which wheels are those again (I forgot)?
#37
Now, for track , I use Enkei RPF1s - same size/offset. They require an 8mm spacer upfront but clear the rear WW calipers without a spacer.
What Wilwood rear kit are you fitting RPF1s on? I just got a set of them in 4x108 and they're not even close to fitting mine (11.75" rotor)
maestromaestro
#39
The fronts are something that they tagged with Fiesta Platinum model tag, for some reason. The rear kit is not offered for a Fiesta, so it is something that 2JR put together. 8 mm spacers are needed for the Enkeis upfront, but the rears fit without a problem. The fronts are Dynapro 6 piston calipers. I also use Wilwood Rotors; converted to 4x100. I have a lot of that in my "signature"... :)
#40
I got my wilwood stuff from 2jr too, Joe is the one who told me about previously fitting RPF1s with them. I’m trying to figure out what the difference is. What size is your rear rotor?
