I recently replaced my washer spray pump because the previous one snapped at the flimsy connection to the tubes, but now it won't spray the front windshield at all when I press the side button on the stalk.
Oddly enough, the rear spray shoots now when I push it, which it never did before. This is also the first time I have used that spray because it never worked before and I didn't know how to turn it on.
Has anyone else run into this issue when replacing the window washer spray pump?
I appreciate any help and thank you in advance!
UPDATE:
It's fixed now. To anyone replacing the washer pump: Make sure the 2 hoses are on the correct side.
Mine were swapped.
UPDATE:
Mine were swapped.
![Confused [confused] [confused]](/images/smilies/confused.png)
