Well water from sprinkler discolored front bumper?
I've tried with no avail.
How do I get the discoloration out of the clear coat?
I’d reach out to Chemical Brothers or other detailing experts
Chemical Guys. Yeah like the band! or not
OneFord
Haha I know was jk.
I sent them an email. Probably should have just done that :)
Haha I know was jk.
I know I’m just effing with you. Go to mountuneusa and they have a heavy duty water spot remover
slopoke
If it's hard water deposits, use vinegar to remove the spots.
OneFord
It's more like an iridescent discoloration. There are not hard water spots.
Pour yourself a glass and tell us what it tastes like🤮
What if he does that and then crumples up? How would we ever know unless someone volunteers to go check on him and then thay could taste it and we might be able to find out. :sick:
slopoke
If that's the case, you have much bigger problems. Time to get your water tested.
If they tasted it they might crumple up too then we will never know what it tastes like
The acidity of the water combined with the strong sun light, might be responsible for conditions that favor embedding of fine, fine particles. But yeah, with people setting their well water on fire and such, I'd be worried there's some sort of solvent chemical or something in there too. Maybe some fuel station(s) have leaky tank(s).
Yeah the EPA has been underfunded, undermanned and virtually toothless in many cases. The companies know this and some take advantage to save a buck at the workers and communities' expense. But that's okay because we have an affordable health care system that will take care of us. Oh wait...
Like engine oil analysis, there are labs that test water samples sent to them. However I don't think it's as simple as testing a water sample and magically getting each and every foreign component. There are specific tests for specific contaminants and if you don't run that test, you don't necessarily find that contaminant. So they have to know what they're looking for; and it can get expensive to run a great many different tests.
If it's just discoloration, park it in the sun. The sun will bleach out the color. I nearly killed the apartment gardeners when they got weed spray on the car (green which dries yellow). Sure I cleaned it, but it was a stained yellow in the clearcoat. Gave it a month in the sun and it faded away. Easy as that. But very annoying!
OneFord
I ended up using a Meguiar's G17220 Ultimate Compound and it buffed right out.
