Ham Radio Install - Antenna Placement
North Carolina
I've done some quick research, and haven't seen a definite answer yet.
I am slowly installing my ham radio (Kenwood TM-V71) in my 2019 FiST. The hangup being the routing of the antenna line.
I will not be drilling a hole im the roof or using a through-glass mount antenna, or mag mount. I have a Diamond K400 series lip mount that I intend to mount on the lip of the hatch. The trick is safely routing the RF line back into the car.
Does anyone have any experience with this or suggestions on getting the cable back into the cab of the car?
XR650R
Eerie
If you're using a separate antenna, you'll just have to look at how to route it. Run it from the radio, through the A pillar, and see where you can go.
I don't know, but I suspect you can route it over the doors, and run it out through one of the two holes at the hatch.
A
North Carolina
It's definitely a separate amtenna. AM/FM/XM antennas are not compatible with amateur radio bands.
Shouldn't need to use A-pillars, as the radio body will likely be sitting under the driver or passenger seat. The faceplate, known as control head, is already remotely mounted on a bracket in the front passenger area and angled into the center console area (I can provide pics later).
Knowing there are holes in the hatch, this may help immensely! Any pics of these holes so I can continue planning? I'll be sure to take another hard look tomorrow as I continue the project.
XR650R
Eerie
Just open the hatch. There are 2 holes running wires and hoses to the hatch from the roof.
I'd pull up the rubber and see what runs where.
maestromaestro
Houston
Ham radio in a FiST. Just no. Just say no. It IS wrong. Even if you were a convoy of FiSTs.
maestromaestro
Houston
Some people just like their ham radios. No reason you couldn't put one in a FiST.
Some people wear polka dot shirts with striped pants. And press their jeans, if I staying with this analogy. Just because one likes to do certain things, it doesn't mean that we, as a society, should condone such behaviors. So, just like Nancy said: "Just say no"! :ROFLMAO:
maestromaestro
Houston
Ham radio 📻 is an important tool and more people should learn how to use it. When the shit hits the fan, you’ll be glad to know a ham operator.
When the 12 foot man lizards from Bilderburg come for your guns? Or the horde liberates them aliens from Area 51? Or zombies? My money is on the Morse code and smoke signals.
The Kyle's are hoping to storm Area 51 and free the aliens....its already been planned!
Clint Beastwood
Laguna beach
What's the HAM use-case here? Just hobbyist, or with a specific purpose (if you don't mind my asking)?
For people knocking it - it's a hobby just like looking at boobs on instagram, different strokes for different folks. (and lots of strokes for those boobie lookers)
