UPDATED TROUBLESHOOTING LIST
Starting to think this is real knock..
Here is what I have investigated so far without success in trying to find the reason for cylinder 1 knocking on E85 but the others not knocking at all:
- New posi-tap connection for aux fuel cylinder 1, fixed the remaining lose connections
- Swapped coil pack from cylinder 1 and 2
- Removed plug on ST200 intake box for the bottom hose (thought maybe I was starving the engine of air)
- Swapped spark plugs 1 and 3, no change
- Upgrade passenger side engine mount to vibra-technics, decreased torque steer but no change to knock count
- Secure OEM exhaust manifold heat shield with lower bolt, no movement, no change to knock
- Nothing is making contact near the engine/knock sensors
- Removed skid plate, no change
To be completed next week (engine mount is en route and injector just ordered)
- Replace cylinder 1 direct injector with new injector
- Use boroscope in cylinder 1 to look for piston damage or evidence of knock
- Replace CP-E lower engine mount with another upgraded unit (although no movement detected from CP-E unit)
Reallyyyy hoping it is just a clogged injector since I have pretty much ruled out everything else.
