ruthenium plugs
Trader history for ROCKYFiestta (0)
ROCKYFiestta
Colorado Springs
just wanted to make sure and ask before I pull the trigger on those plugs if it will affect our tune adversely or not. the whoosh site says they are gapped at .30 or .28 or .25 as well(which would be best for the dizzytune). I am currently running your 91 tune v2 and I sometimes run the e30 but not lately. was hoping it might help remedy some of the - corrections I am currently seeing.
https://whooshmotorsports.com/colle...at-range-1-step-colder?variant=30685754785931
Plugs will not effect your tune...if they are the same heat range....it most likely will not help with - neg corrections.
You will always have Corrections....its just the Severity of them that matters. It could be a variety of things causing them. When you car sees knock it brings timing back so it can't hurt itself. It's a fail safe built in to keep the Engine from killing itself. But sometimes it false knock* due to Exhaust banging around....RMM....charge pipes hitting frame or engine. Ask your tuner if you are worried and they can help address the problem.
ROCKYFiestta
ROCKYFiestta
Colorado Springs
ok thanks for the great info. I must have something going on will get to datalogging then and see what happens.
