Weird behavior
west Columbia
So I did a resonator delete and went for a drive and every seemed good. I went to make a rev video and when I go wot in neutral it's almost like the car floods or stops firing. It's not rough and the car doesnt shake. I'll rev to about 3 then go wot to do a quick rev higher but nothing will happen. If I do half throttle all seems normal. If I go wot while driving all seems normal. I cant imagine a resonator delete causing this, so maybe I knocked something lose or pulled an 02 sensor wire too hard maybe yanking exhaustoff? Everything seems fine underneath. I wouldn't need a tune update for a resonator delete would i?
Sent from my SM-N975U using Tapatalk
FJ16
Wichita, KS, USA
Your tune shouldn't be hampered at all by a res delete... throwing any codes? If you damaged any 02 sensors you would likely have CEL popping up.
TheBlackFist
west Columbia
Nope...no codes. I switched to a different tune and it stopped. Currently flashing back to my final tune to see if it does it again.
TheBlackFist
west Columbia
Ok, I flashed back and everything seems copacetic.
flbchbm
Sterling, VA, USA
Honestly, I just did a quick image search for "multiple demons", snipped and pasted. I'm at work and have soooo many other personal things to do...oh, I mean work-related things to do...
You may have noticed I try to take the time to personalize my welcome's to new users. If not, I use one of many thumbs up pics I have at the ready.
