TPMS remove from ignition cycle
I've put 100ish miles on a brand new set of wheels and tires that I ordered with new tpms sensors, and randomly out if nowhere my tpms light kicked on. I checked my tires and all were within a pound or two of where they should be, so I refilled them to their correct pressures and continued driving. It's been another 30 miles and I can't get the light to go away, in fact it flashes and stays lit after a short time. Does this indicate that I may need the sensors retrained?
Also side note, last time I started my car a message popped up about there being no tpms sensors and asked if I wanted to remove from ignition cycle and I clicked okay before thinking of taking pictures, good news is the light is gone now and my tires are currently filled correctly, but I'm concerned I may have disabled the alert from coming in should I need it.
XR650R
Take it back to where you got your wheels put on. They have a handheld deal that can revamp the sensors and make sure they're working.
personally I was too lazy to swap my sensors from my old wheels, so I just turned off the system in forscan
I’ve been trying to turn off the alert on my ignition. How did you remove it?
