Lc7i install help
Somerset, MA, USA
Hi I almost done with my new radio set up. The only thing left is to take my Lc7i inputs and the outputs from my 4 channel amp and hook them up to their proper location. The only issue is I’ve been told so many different ways of doing this and I don’t want to do it until I understand that I will be done right and working properly. My plan was to cut into the speaker wires in the door sill and connect the input to the side of the wire that goes to the radio and the output to the side of the wire that goes to the speaker. Can anybody confirm that this will work or help me fine a better way of doing this ? Please help. IMG_1344.jpg
Rocketst
Chesapeake, VA, USA
I personally soldered the connection on the back of the sync 3. Either way your accomplishing the same thing so yes this will work. Running the input wire back to your equipment then running a wire from there back to the speakers will accomplish what you want.
Fiestig
Pacific Grove, CA, USA
