Mountune BBK Install
Indianapolis, IN, USA
(front) 4 piston calipers with 330mm slotted rotors
Brembo / Mountune Calipers
Adapter bracket
Be sure to place the screws on exactly as show due to the length of the screws and mounting points on the hub and caliper.
First things first take off all of that.
Notice how these bolts are placed because when your installing the adapter plate bracket the bolts will need to go in the opposite direction screwing themselves into the unit itself.
Do not reinstall the dust shields they just get in the way. Be sure to tighten the adapter plate bracket unit before adding the rotor.
After you place the rotors in location (floating) you then install the calipers which keep the rotors in place.
Swap out the O.E. brake lines with an upgraded pair.
If you completed the job correctly it should look like this.
Here are the tools used on this install.
Sockets 8, 10, 13, 15 wrench 3/4, 11 and a Flathead screwdriver.
Don't forget to torque everything to O.E. spec with your trusty torque wrench.
Here is the weight difference. the old setup with rotor, caliper, pads bolts and dust shield is 30lbs
The new setup with everything including hardware weighs only 28lbs
Huge upgrade in stopping power (110%) and a a loss of 2lbs on each side.
Stock wheels (rims) wont fit i would suggest going 16x9 as a minimum or you may have a problem fitting your wheels with a brake kit this large.
Spacers or longer studs maybe all you need to help.
willz2008
Newport, UK
Hi there ,
I have the same Brembo brake kit that you installed , the Brembo calipers I received are identical , rather than a right and a left , was this the case with your calipers or were the left and right slightly different for example where the bleed nipple is located.
Any response would be greatly appreciated
Thanks
Rich
iGilgamesh
Hi there ,
Thanks
Rich
The calipers are identical the only way i knew which side goes where are these tiny arrows on the calipers, you want those facing the front of the car.
Tarnów, Poland
Do you by any chance remeber the brake pads part number, or you have their dimmensions?
I am asking beacuse i don't know if i have bought the same brake calipers as their paint was removed and they look very similiar to mountune.
burt2000
Belfast
Long shot here as this thread is old but does anyone know where I could get the brake lines for this kit. Seeing as Mountune have superseded it with a new version. Thanks
