SLD Airtec Oil Cooler w/Thermometer (Brand New In Box)
Trader history for The Cuzi (0)
Twin Falls, ID, USA
Hey FiST'ers,
I have a new in box Airtec Oil Cooler w/Thermometer that I am selling. I would return but I am past Ron's return policy timeline. No worries, so, offering it to you folks. The cooler and all gear are still in the factory sealed bags. Product quality looks great. I planned on putting this on a stage three pro alloy but due to finances that is no longer an option. Rather then let it collect dust on a shelf I figure I'll sell it. I paid $441 with shipping a month ago. I am asking $300. Shipping will be $25 (I'll pay whatever is beyond the $25 for CONUS shipments).
$300.00
$25.00 Shipping
Please send a direct message through the forum if you are interested.
Thanks
The Cuzi
Twin Falls, ID, USA
tried doing research and can't figure out if this deletes the water to oil cooler or not?
It does eliminate the oem water/oil heat sync. The thermostatic sandwich plate takes the place of the oem water/oil heat sync. The coolant hoses are connected by a small pipe in the kit so the coolant flows normally and the thermostatic sandwich plate controls when the oil is pumped through the oil cooler.
HardBoiledEgg
Fontana
I SAW YOUR PAST THREAD WITH SOME DECENT INFO
WHY DIDN'T YOU DO THE INSTALL?
I THINK ID HAVE TO MAKE MY OWN BRACKET ANYWAY CAUSE THAT MOUNTS RIGHT WHERE MY BRAVO INTERCOOLER DOES
The Cuzi
Twin Falls, ID, USA
I was planning to put this on a stage three pro alloy which wouldn't require any custom brackets. But, because of finances, I'm not going to be getting that intercooler so this install was a moot point.
I'm not sure about the bravo intercooler, but the pro alloy stage three had the same intercooler depth as the airtec (~50mm from my research) so it would fit with the supplied bracket.
TemecFist
Temecula
I would take this if I could find a way to mount it to an aftermarket crash bar.
The Cuzi
Twin Falls, ID, USA
If it is a tubular crash bar I would assume that is in the range of possibilities but I don't know of an off the shelf solution. There is a member on here who also mounted this to his crash-sensor-bar with a custom bracket.
The Cuzi
Twin Falls, ID, USA
As an update, this is still available. Asking $325 shipped for an item I spent $441 for.
