Help me!!
Veronika
Lithuania, lithuania_municipalities.kgm
Hey !!!
When the diagnostics are turned on, I showed that there is no tension before vesgate - how to handle? Contacts cleaned up, nothing has changed, maybe a mechanical failure? and where does it handle it?
What could be the problem : overboost disappeared, fuel consumption increased. We checked the turbine, blow off, everything is ok.
Virginia
By "vesgate" I assume you mean wastegate? That's the device on the side of the turbo. It's a solenoid and a mechanical arm that actuates the wastegate valve. If it's loose, that's not good, and the source of your problem (basically a constant boost leak).
Also, I think this should be moved to the troubleshooting forum.
Se7eN
San Juan, Puerto Rico
I think the Boost Control solenoid might have died but if it has a OBD2 Code it's be nice to know what it is. Usually Can google the code and get diagnostic steps
