Code P00C6 and P0301
Los Angeles
Hey All,
So recently my car stalled on me and wont start now. I scanned it and was given two error codes P00C6 and P0301. I looked it up and P0301 seems to be a cylinder 1 misfire and P00C6 is a fuel rail pressure too low - engine cracking. I've searched everywhere and couldn't get
a solid answer on how I can get it fixed. Has anyone ran into this issue or has gotten those codes before? Im hoping to see what troubleshooting I could do before I take the bullet and take it to a dealer.
ALL STOCK 2014 FIesta ST MI. 78000
Anything helps!
Thanks everyone
Do you have a Ap3/ Cobb Accessport? You can check the fuel pressure reading with it. Is the vehicle under warranty of 5 yr/60k powertrain Warranty still ?
M
Los Angeles
Nope on the accessport. Im just using a regular OBDII Scanner. Its over the warranty. Its a 2014 model at 78000 miles
There are a couple of threads Started with Fuel related sensor issues. There is also a good post from another member of Adam Brunson's Facebook post on how to identify if you have a bad fuel sensor. in all that some where using an AP3 though to monitor the pressures.
Here is Adam Brunson's Facebook post....its a good way to check the sensors.
Is the only way to do it with an accessport?
You may have to have a better scantool than a local parts store one* they can only do so much for live feed data.
M
Los Angeles
Update: I replaced the spark plugs and coils. One cylinder had a spark plug that was a little mosit and smelled like gas. The car cranks for a few secs before starting but it sounds rough. Idle is high and maybe 30-40sec later it will stall out. I've read multiple threads saying it might be the low pressure sensor so I got a replacement part for that and will be working on it tomorrow. However, I did notice a gas smell as I was trying to start it and looking into the exhust a little bit of white smoke was coming out so im not entirely sure what it could be.
White smoke usually is an indicator of Antifreeze * i hope it isn't for your sake! Keep us up to date
M
Los Angeles
yeah I was thinking that too but when I smelled it. I was smelled gas and not coolant but we'll see how it goes. Some threads said it could be a bad fuel injector? could possibly make sense since one spark plug had some gas on it and code was throwing out cylinder one misfire.
An injector that is leaking down/failed* check the oil level also and smell it for gas. If it smells like gas time for an oil change to avoid bearing washout.
Which sensor did you buy? I did a DIY on the LPFS near the HPFP. You can check that one out for reference if you'd like also.
M
Los Angeles
I bought the LPFS. However, Im still havng a rough idle and start up after replcing the coils and spark plugs. Not sure what else it could be.
PunkST
Menasha
It could very well be a fried injector. Sounds almost exactly what my wifes gti did.
