Scottsdale Dynocomp Dyno Tune on e30
El Dorado Hills, CA, USA
Haven’t posted these results but took my FiST in for its first time on the dyno for a dyno tune and a new intake. I was running Dizzy e30 before and based off of vdyno readings numbers were around 230 HP 280 lb ft of torque so the difference was astounding!
Rotate the picture * my neck hurty!
I suspect that dyno is calibrated favorably. If you are on a stock Turbo the Vdyno is closer to accurate than than that dyno. I am sorry but the stock Turbo will just not flow 250 whp. To do that it would have to be around 275 to the flywheel.
NJ
I agree. Limitations of the stock turbo/fuel system are pretty well known by now. It is physics as far as how much air it can flow.
