- Member ID
- #19442
- Messages
- 606
- Likes
- 911
I went to install my Boomba shifter kit, pulled my battery and the box was full of dried battery acid. Found acid on the back of the computer and the bracket that holds the battery box. It looks like the acid leaked out where the top of the battery is bonded to the case, it's a stock Motorcraft, only 2 years old with 7,500k. I had to drill the plastic rivet out that holds the metal frame into box to get all the corrosion out. I'll have to get paint and primer when I go get a new battery. Oh and the pocket where the back bolt in the bottom of the box goes was totally full of acid. Good times were had by all. I did get the Boomba parts installed.
