Front bump stop C1BZ-3020-B discontinued. What are other options?
Reynoldsburg
I have all the parts to put together front assemblies made up of Swift Spec-R springs and Bilstein B6s on the way except for the front bumpstops C1BZ-3020-B that were removed from the order because they are discontinued. I wanted to build them up ahead of time and keep the stock assembly assembled. Is there an alternative for the bumpstops that is available? Could I possibly use the regular Fiesta bumpstops, D2BZ18198A instead?
Thanks,
George
St. Paul
I used the KYB bumpstops that are on Rockauto when I put together the B8/Swift Spec-R springs 2 months ago. they worked just fine.
akiraproject24
U.S. Marine Veteran
Pennsylvania
i was gonna say KYB as well. Grabbed a set from Rock auto for my honda, I think they are actually an upgraded material too.
G
Reynoldsburg
Unfortunately Tasca halted my order requesting my input because they were discontinued and I just got an email today from fortpartsgiant saying my order was cancelled because they were discontinued. It seems that they both show the bumpstops in stock even when they're not.
Call any Dealer and have them run a dealer locator* they will then find any dealer with any NOS parts.
G
Reynoldsburg
Thanks TyphoonFiST. I'll have to remember that next time. I ordered the KYB parts and should be here tomorrow.
albany
hi,
I purchased the same thing: SB101, B8, Swift spring.
however, the bumper stop is too small to put onto the B8. inside diameter of the bumper stop is just too small to fit the diameter of B8 and it sits on top of B8 about at least 1/4 in (maybe a bit more) so the thread area is so short.
how did you get SB101 to fit? Thanks
London, ON, Canada
The thing about bumpstops is they're foam, you can modify them. Eg. You can find something aftermarket for a different car you can cut it. I've done it before. Eg. My old Miata champcar had cut foam bumpstops. The OEM was rubber
Yes, the exact foam density has a bit of a suspension tuning aspect, but I'd suggest it will be okay.
I'd guess you could probably drill out the hole in the middle if it's too small, but that probably sub-ideal.
