Both BDA's and a temp sensor.
Raistron
Active Duty U.S. Air Force
Not a real address
Wish me luck gang, doing both Blend Door Actuators and the cabin air temp sensor, and cabin air filter tomorrow. Going in almost blind, ought to be fun.
Why the cabin temp sensor? Just curious....did it fail?
Raistron
Raistron
Not a real address
Well, I thought I would. Local O'Reilly's had neither in stock, so I ordered them both through them, supposed to be next day, but 2 days later and still had nothing, refunded both and getting the DORMAN ones online 1 day shipped.
Raistron
Raistron
Not a real address
All three have been replaced, clicking had thankfully, if only temporarily, ceased. The temp sensor was completely coated in dust, which may have been causing the wrench light for it, unsure at the moment as I need to clear the code and see what it does.
For the record for my own testing sake, both actuators were swapped at 118,780 miles, I'll make note of the mileage if they break. Gonna take the old ones and ask a buddy of mine who does a lot of fine machining to have a look and see if it would be realistic to replace those gears with metal.
Raistron
Raistron
Not a real address
Can confirm code went away after clearing, so it was the sensor, can't remember exactly what it was but it was something like b1a6xxx cabin air temperature circuit short or open.
Wrench light itself refuses to go away for the time being, but FORscan can't find any codes, so I'll just ignore it for the next few days and if it persists I'll put the reader back on it.
Auto fan setting nearly always runs the fan on a low setting. Might help to run on a higher setting? Also check cabin filter to see whether air is bypassing it.
Dorman typically makes reliable products. It's not really the gears that fail, but the potentiometer style "sensor" that allows the system to calibrate and detect the position of the blend door. WHen the system is unable to calibrate, it begins grinding the gears; to the point of failure.
EDIT: Ultimately Ford needs a different (more reliable) sensor method for detecting blend door positions. In my experiences with similar devices and switches, covering those parts with silicon spray, significantly enhances their reliability. It coats the contact surfaces, reducing corrosion/oxidation by limiting exposure to air.
Do you have An Ap3/Accessport ? The wrench light may be a Maitenence reminder. It can turn it off and Forskin can also.
Raistron
Raistron
Not a real address
I actually have one on the way from Ron over at Whoosh, I'll have to look on Forscan again to see if anything is due.
Raistron
Raistron
Not a real address
Resolved, it was an oil life reminder, turns out every time I thought I was resetting it, I wasn't doing the procedure quite right. Go figure lol
