I haven't posted here since my car was new:
115K mile 2015 Fiesta ST, daily driver since day one,
99% stock (aftermarket intercooler).
Started running rough & Check Engine Light came on Tuesday while driving about a mile between jobs.
An hour or two later, CEL was still on when I started it to drive home.
About 8 miles into the commute, the temp went full scale hot.
I turned the heat to max, brought the temp back to half scale
& I got off the highway to shut it off/let it cool down for about a half hour.
I was about 2 miles from a safe place I could park it overnight, so after the half hour rest I limped it over there,
temp stayed around half scale, but now the heat would only blow cold so I know I was down on coolant & I didn't trust the gauge at this point.
Before I left it for the night I put a code reader on the engine and it said Cylinder #1 misfire.
Went back the next night, filled the coolant & changed the #1 plug.
Fired right up, no CEL, no rough idle.
It drove home as good as ever.
Temperature never went above 194 degrees (according to the code reader) on the ride home (40 miles).
This morning, went to start it up, and it did a half a crank and it stopped,
then another half crank and it stopped cold again.
Pulled the plug out (suspecting coolant), yep, plug was wet, smelled like antifreeze.
Cranked the engine with the plug out, it spun no problem and it blew all the water out.
Question:
Anyone else run into a sudden coolant intrusion like this?
Never had any issues before, never used a drop of coolant.
We also have a 2016 1.6L Turbo Escape and it needs coolant from time to time, but never has my car needed any.
For the moment I'm going to hope the short block is OK and buy parts for a head gasket & timing belt since it's time for that anyway.
If its the head and or short block when I get in there I'll have to decide between new, rebuilt, or junkyard replacement.
Any thoughts?
Thanks.
Question:
Any thoughts?
Thanks.
