15" Wheel PSI?
Central CT
I just had some Falken Azenis RT615+ tires sized 205 50 15 mounted on a set of Sparco Terra 15x7 wheels. These are to be daily driven with a bit of spirited driving. What is the recommended psi? I've seen everything from 31-40 psi in past threads.
Max 50psi cold
Thanks
FiestaSTdude
Cary, NC
fronts/SL load rating: 32psi
Fronts/XL load rating: 33psi
Rears/SL load rating: 29psi
rears/XL load rating: 30psi
This will get you the stock load/weight ratings, some people do prefer slightly more or less pressure
Found using this site: https://tiresize.com/pressure-calculator/
I didn’t know that pressure changed with tire size! Thanks for linking the calculator
