- Member ID
- #29616
- Messages
- 1
- Likes
- 0
Hello everyone!
I just scooped a 2018 Ford Fiesta ST, and I want to wake it up and make it a very fun little daily.
I would like to stick with stock turbo and fuel system for now, however I will plan to upgrade this eventually for a stage 2 (turbo) and 3 (fuel) build.
I have been told both the Intercooler and Radiator are subpar for even OEM, as well as the rear motor mount, is there anything else that should be upgraded to improve the vehicle's reliability?
From you guy's experience, what brands are recommended for the following items?
Thank you guys in advance! I will continue reading through other's builds on this site and see what I can scrounge up.
- Radiator, (Is it recommended to also get the upgraded "Race" thermostat that opens at 160?)
- Radiator hoses,
- Intercooler,
- Intercooler plumbing,
- Intake, (Is a drop in filter enough for stock turbo, or will a Short ram or full cold air perform better before the turbo upgrade? It might make more sense to go ahead and prepare for the future, right?)
- Exhaust, (Cat back only? or downpipe as well? or should downpipe only be done with the turbo upgrade?) (And is 3" functional for stock turbo, same situation, prepare for the future lol)
- Rear motor mount,
- Suspension, (I keep seeing Bilstein B6 shocks/struts, but is there a specific spring that is recommended as well? I do not want to lower it as it sits perfectly IMO now. Is there a coilover set that is better than the B6 + springs?) (Other that struts and springs, are there other suspension components that require upgrading? I keep seeing sway bars on websites, are the OEM sway bars not good?)
- Brakes,
- Tuning, (I have been advised to get the Cobb Motorsports Access-port for tuning, but not to use the rest of their products as they do not perform as well as similar price point or cheaper brands, and that their rear motor mount's fail prematurely due to rigidity.)
- Wheels/tires. (I have read people saying they go down to 15s for more sidewall, which would definitely be more comfortable for daily driving, is there a specific size/offset that you recommend?)
