FS [Socal] Price drop 3/10 - Weathertech window deflectors, Kruise Sport hatch filler panel, 3 piece mesh wheels
Trader history for initiation (0)
OC
**Accepting trade offers for stock wheels with good tires**
Weathertech window deflectors - front and rear
I have two sets of these available, one new and one used.
Brand new in sealed box, front and rear - $65
Used - free if you buy something else
The used set has one damaged rear deflector. The corner of the piece that goes in the window track broke off so I wouldn't trust it to hold with your window down, but if you keep that one rear window up it should be fine.
Timestamped photo attached to bottom of post
Kruise Sport smooth hatch filler panel
Super rare Kruise Sport filler panel for the Fiesta ST (installed pic for attention). Kruise Sport was a UK based company that went out of business around 2020-21. Whoosh was importing their parts for a while but there was a rather public falling out between them so I don't think many of these were sold in the US.
This is made from fiberglass with stainless steel inserts for mounting. The finish is gloss black gelcoat and it will need to be painted or vinyl wrapped as there are scratches/defects in the gelcoat. I had it vinyl wrapped and the scratches/defects did not show through.
There is a small crack where the hatch handle goes. I didn't notice the crack until removing the vinyl last week so I think it's still structurally sound. The mounting bolts are a bit rusty but are M6x1.0 thread and easily replaced. I believe these require modification to fit the factory backup camera.
Asking $175 picked up in Orange County, CA. I really don't want to ship this but will if nobody local is interested.
PHOTOS --> View: https://imgur.com/a/M47jg0s
CSi Style 32 mesh wheels - 15x7 4x108 +35
I know the sticker says 4x100 but I can assure you they are 4x108. I don't know much about the company other than they were made in the late 80's and early 90's, sold by TRD as aftermarket wheels for the MK3 Supra, and I've also seen them in BMW fitment.
These will need to be refurbished, as you can see. I started to strip one center and determined that's better left to the pros. If you send a wheel center to or accurate measurements to SRR Hardware they can customize their blank lips to fit, they can also change the offset or step them up to 16 or 17 inch diameter. The current lips would probably work but they don't look great. Lots of curb rash, dings, and a nice dent on one lip.
All hardware is accounted for and bagged. Needs to be polished up but should be okay. These wheels will require 63.7mm to 65.1mm hubcentric rings in order to mount.
I'd like to sell these locally (Orange / Los Angeles County) but would be willing to ship at the buyers expense.
$300 (local pick up in OC/LA)
PHOTOS --> View: https://imgur.com/a/fers6wb
XR650R
Eerie
What happened to cylinder 1?
The world may never know.
I
OC
How blown is blown? Would you say it is rebuild material? Sleeve material? Or just straight hole in the block?
No holes in the block, definitely can be sleeved. A couple cylinders have developed small cracks at the top of the liner which is common with these motors. They held compression fine but I would still be hesitant to use them. I'm not sure if the liners could be bored out to be useable.
I
OC
Engine block + blown engine sold and removed from post
I
OC
Weekend bump, all prices dropped. Make me an offer, I'm eager to get rid of stuff.
I have some more parts I'll be pulling off over the next few weeks, hit me up if any of this interests you and I will pull it off to list it sooner:
- Coolerworx shifter - $525 shipped
- Kruisesport filler panel - $400 shipped
- Diode Dynamics SS3 LED fog lights, yellow / sport - $150 shipped
Edit: Holding off on selling these for now, I've been enjoying the car again and am going to keep this stuff until it's time to sell the car
I
OC
Prices dropped! $950 for the S280, $325 for injectors, and $950 for the Rotas with tires
San Francisco
i wonder how many miles on the coolerworx shifter?
Santa Rosa
Hey, outta curiosity, what was your suspension set up? I want to try those RS4 225/45 but curious if I'll have issues on 1" lower spring and stock camber settings.
I
OC
Just Mountune lowering springs. I think you'll be ok.
Catch can is pending sale
I
OC
Thread Starter #18
Post updated and all messages replied to. Injectors are sold and I'm holding on to the Coolerworx for a while longer. Wheels are all that's available right now
I
OC
Thread Starter #19
Prices on wheels reduced again. Happy 4th y'all.
I
OC
Thread Starter #20
Diode Dynamics SS3 sport yellow LED foglights + chassis bracing added
