UPDATED 1.6L BLOCK
  • Thread starter Deleted member 21349
  • Start date
D
Guest
My updated 1.6 block arrived, haven't fully unboxed it yet this is the only photo I have for now
However i did do some digging from this picture it has thermostat housing design and coolant jackets designs from our mk7.5 engine, while having the cylinder walls from the 1.5 block
none
What is the block p/n? Should be stamped on the side, then we could scour the world for more of these mythical blocks.
D
Guest
ill get it for y'all this weekend
D
Guest
Finally got most of everything in the mail, only think I'm waiting on now is the v2 Mountune Camshafts, I have the old motor just sitting on motor mounts waiting to be pulled
3rd picture is the part number for the updated block with the old style thermostat housing
D
Guest
yes
the only thing i dont know about is Jason from Dizzy told me I have to shim the springs for the cams, so i have to figure out how to do that, if anyone has any input on how to do that it would be appreciated
D
Guest
Been slow at work spent the better part of an hour trying to find the short block on various ford parts websites could not find it
D
Guest
yes thats where i bought it from but was wondering if it was sold elsewhere as working with poopspeed is painful
United Kingdom
I haven’t seen the new block design advertised anywhere else. It could be worth contacting Mountune in the UK to see if they have any insight. They’re by far the most helpful people I’ve ever dealt with.
Burlington, NC, USA
It’s amazing how useful Mountune UK is when considering how absolutely useless Mountune USA has been the last few years.
none
yes
It is a pretty easy, but tedious task. Here's the instructions: https://www.fofiesta7.com/ford_fiesta_valve_clearance_adjustment_general_procedures-184.html
You need to mount, measure and make a chart of the clearances. Then you can start mixing and matching. The cups come in different sizes and are noted on the inside what size they are.
When I did this it was almost second nature to do the tourqe sequence on the camshafts on the last and final install :sleep:
Pharr, TX, USA
Any more information on the updated block? I would like to purchase one. Mine is a time bomb being held together by puma speed shims and a bottle of barsleak copper seal.
D
Guest
Im really not sure I posted pictures of part numbers, and tried finding it on fords parts with no luck, but if you wanted more details it might be worth emailing pumaspeed
D
Guest
My Mountune Cams should be shipping any day now
none
It is no longer available at pumaspeed, but if you want a solid block, this might be a solution: https://pumaspeed.co.uk/product-Pumaspeed-Fiesta-ST180-Ductile-Iron-Sleeve-Liners_18033.jsp
It is not a cheap solution or quick-fix by any means.
