- Member ID
- #32490
- Messages
- 23
- Likes
- 2
so i’ve posted before and for those who haven’t seen. everything is new under the car. inner/outter tie rods, sway bar bushing and end links, control arms and ball joints. front and rear whoosh centering kit. i’ve have multiple alignments before all that and now 3 after all new parts. my car doesn’t feel correct and the answer i’m getting from shops is “your alignment is spot on and can’t find anything loose or broken/bent. might be your tires”. my alignment looks spot on but my steering wheel isn’t straight. when I reverse and out wheel straight the back up camera lines aren't centered. steering doesn’t return to center properly after turning. Torque steer is real bad even after installing RMM AND PSMM. it’s very uncontrollable under load but off throttle it pulls left. just left shop this morning and said everything checks out and your tires are too much of a low profile for our streets. btw they are the stock bridgestone potenzas. forscan doesn’t give me option to reset or disable drift pull compensation like others have said to try. forscan showed a dtc code u2100 under the pscm. idk what to do now.
