Looking to purchase Fiesta ST transmission to
Trader history for SneakyBobinson (0)
Hey, unfortunately my transmission was damaged by some debris on the road and is now leaking fluid. I have attempted all the jank fixes like JB weld with little to no success. So, now I am reaching out to see if anyone might have a good transmission for sale that can be shipped to my home address or if anyone has suggestions on the best place to purchase a used unit from. Thanks!
this should be in the WTB forum but maybe copart, local junkyards, both tips performance on fb, or just trawl around for part outs
Check out PumaSpeed. They will ship them from the UK for less then they are listed on car-part
Just did this…about $1,800 delivered from the UK. New LSD, LSD bearings, and axle seals are installed.
My transmission from PumaSpeed ended up about $2,700, but included the ST200 pressure plate, disc and new flywheel. Puma claimed less than 40,000 miles and supposedly has Quaife. Did you have good luck with yours, could you tell me, through driving feel, that the part actually has an LSD installed?
I got a transmission with a Quaife from PumaSpeed a few years ago. Shipping took like 2 days from the UK (impressive), but the packaging was a bit lacking, however, transmission has worked without issue on track for a couple years now. Casing was definitely opened as they used quite a bit of silicone to re-seal it. For sure has a diff. installed, feels very different on track. If it came down to it, I'd certainly order another one if I needed to. Only issue was the plastic vent cap got broken in transit, but I just swapped the one from my stock transmission.
I tried to buy a used transmission from Pumaspeed and somehow it was returned to them without even passing the border. I just re-ordered the quaife gear box afterward, hopefully it can be ship over. My transmission was shot (bearings came loose and shot through the housing). I was going to send it to Clarke but it was beyond repair when I opened it. I was surprised my engine outlast it while running at 35 PSI.
Was this very recently? Typically they use DHL, and right now DHL has put a temporary hold on business to consumer imports with values over $800 because they have to go through the full process now (starting this Monday), where it used to be a simpler process for anything under $2500 value. I have a set of wheels that have been hanging out in customs for the last week.
The one i ordered took about three weeks to get here. It bounced around the UK for about two weeks. I was told by Pumaspeed it looked like FedEx sent it to the wrong hub at first. Anyways when it did start moving it went to France. It did arrive on a small pallet, strapped down, no damage.
They used UPS for that shipment, it was just this past week, now back to the waiting game :(. The other stuff like my st200 clutch and plate were shipped through DHL that arrived within a couple of days.
Nice, they told me that they were unsure of availability. They will probably have to build one which may take time.
I had tariff anxiety, really didn’t need it, but I decided to pull the trigger. I also started accumulating all the clutch parts.
How tough is the install for a DIYer? Looking into shops to put an LSD in mine while changing clutch/flywheel but if the pumaspeed trans with quaife and clutch/dual mass flywheel can be delivered to the US for $2800 that sounds like an obvious choice?
Provided you are at least somewhat mechanically inclined, its a fairly easy job. Having a service manual for the first time is helpful, I believe there is still a PDF of the service manual floating around here somewhere.
Getting the transmission out and back in is obviously the major hassle, its not difficult, just a bit fiddly. Having a transmission jack helps a lot (easier to balance the transmission on than a regular floor jack). It can all be done on jack stands. There is a fancy spreader bar that mounts on the strut towers to hold the engine up since when the transmission is out, you no longer have a drivers side mounting point. But, I just use a screw jack under the engine. You need something adjustable under the engine as you will need to angle the engine/transmission done slightly to pull the transmission away from the engine to drop it down. Make sure you have the front jacked up quite high to be able to get the transmission on the jack out from under the car. I usually pull it out sideways through the driver side wheel well.
Make sure to not forget to drain the transmission before dropping it, otherwise you'll get fluid everywhere. (ask me how I know)
You can drop it without dropping the subframe as well. (I can't because of my 6 point brace, and its actually easier to drop the subframe with the brace rather than just pulling the brace). Note that dropping the subframe opens up a ton of room for activities. Also note that if you do drop the subframe, the two main large bolts are torque to yield, so they need to be replaced.
Once the transmission is out, the clutch/pressure plate/flywheel are easy and straight forward. You will want to come up with something to hold the flywheel from spinning to properly torque the flywheel and pressure plate bolts. Ford has a special tool that you can buy, I just made one from a scrap power window actuator and a few nuts and bolts (imagine my surprise when the teeth matched basically perfectly to the flywheel).
To go back in, just reverse the process. Getting the transmission fully home requires a good deal of adjusting, tweaking, and jiggling the transmission. It will fight you for quite some time, the once its in the correct spot it will just slide right in.
Do yourself a favor and just install a new slave cylinder while you are at it.
The transmission has quite a few bolts of different lengths and orientations, so when I got my replacement I traced the outside shape and mounting holes on a large piece of cardboard and punched out the holes to put the bolts in. (basically like a template so I know where they all go)
There are a few clips, groundings straps and other things that attach using the transmission bolts, so keep your eye on those as they will hang up getting the transmission in and out.
The manual will tell you to pull the starter back and suspend it with a strap or bungee, don't bother. Just pull the bolts and let it chill in place.
Make sure you have a cap or plug for the line to slave cylinder, otherwise you'll lose a lot of brake fluid.
I have done this three times now (soon a fourth when my transmission gets back from Clarke), and the only thing I use the manual for now is the torque specs. So, this first time may be a bit rough, but if/when you have to do it again, it will be much easier.
Feel free to message me if you have any questions.
Thanks for the detailed write up! I was wondering about putting a screw jack under the engine- the videos I saw all rigged support from the top but it looked like it would be easier to jack from the bottom if space allows. I've got a 6 point brace as well so subframe would need to drop. Wish I thought of this earlier, was just in there to replace control arms.
Damn a fourth trans? Are you launching the car a lot?
Only two transmissions but 4 swaps. First time was stock out, new pressure plate/flywheel/clutch and puma speed unit with LSD, then I blew up my clutch (one of the friction pucks separated from the disk), so dropped again to swap that. #3 was after I grenaded the puma speed unit (even Clarke is 100% sure what happened, but basically everything but the case halves were toast), so I put my stock unit back in for the next track day(s). It had a bit of input bearing whine, and now after 8 sessions at Pocono it is really angry. So, #4 will be putting the puma speed unit back in later this month when it comes back from Clarke.
ST is about 99% track duty these days, so not an easy life for the transmissions. Hoping the Clarke treatment gives me more lifespan out of them. Stock unit will likely get shipped out for the same next season.
If you have the Pierce 6 point brace or another 6 point that ties into the front control arm mounts, just drop the brace and subframe as a unit. So you take out the two large TTY bolts, the small ones that tie into the chassis toward the back, and the two upper funky star drive bolts. That way you only have to replace the two TTY bolts as it looks like the control arm TTY bolts are in low supply. Last time I looked the price was like 4X what it used to be right from Ford. The manual says to toss the upper weird bolts, but that's just due to the factory loctite.
If you don't have them yet, I'd recommend the subframe alignment bushings. The bushings/brace can be modified to work together with a little work, and the last few times my alignment hasn't even wiggled dropping and reinstalling the subframe.
I just bought one of these and It will be delivered this Monday the 27th. Got hit with a $610 duty fee from DHL that I must pay before delivery. Yeesh! Didn't realize that when I ordered.
Wow, that really sucks. I ordered mine way back because I was afraid of that. I’m actually just getting around to installing mine today. I’m lucky , my friend at work is helping, and he was talking to another tech who decided to come down and help, especially for the bleeding process.
I wanted to post an update on my Pumaspeed transmission which unfortunately isn’t positive. I spent last Saturday at my shop with two friends installing my Pumaspeed transmission, and yes the bleed process takes awhile, but one of my friends had done it before, and though super messy, Monday morning after bolting all the intake and evap, battery back in, the car fired , the flywheel chatter now completely gone, and low and behold , the car shifted right into reverse. Pullled it off the rack, drove it gently around the parking lot. Car shifts like butter at low speed. Clutch pedal is a wee bit softer, new clutch grabs real nice… On to the test drive. Drove about two blocks, gentle acceleration. Transmission growls in all forward gears. Drive it right back to my shop. One friend takes it back out, confirms the noise, right back onto the lift. Double check everything including fluid levels, and … discovered a leak. I could go on, and I’ll update as I hear back from the vendor. I’m weighing my options as far throwing the old trans in when I feel up for it… again. To add to the super foul taste right now, I finally got around to putting my MeisterR coilovers on , and though I only drove for about two blocks… there is a noticeable difference on the street over my Koni/Mountune setup. And that was without any time spent on ride height adjustment, or an alignment. More on that later also. Edit shows original trans “blind plug “ thingy undamaged.
