I've spent the morning running around in my 1.6l Ecoboost transit connect and forscan. Posting here because I cannot find a more appropriate forum for this engine.
Symptom:
A few weeks ago I noticed pulsing power when I am moving from 2000-3500rpm, I assume this is when the turbo is kicking in. If I am on a hill the problem is worse.
Vehicle Details:
Symptom:
Vehicle Details:
- 135k km
- Oil Changes every 5k km
- Transmission fluid changed at ~70k km
- Air intake filter changed often, just changed it again
- Spark plugs just changed (Motorcraft SP532X)
- Borrowed a forscan scanner and have been checking various sensors and readings (attached)an
- No codes shown even after many aggressive runs
- VVT (variable valve timing) solenoid
- Wastegate solenoid
