Intermittent loss of power with exhaust noise and no codes
sczamun
U.S. Air Force Veteran
Indianapolis
Hello, I have a 2019 Fiesta ST with 86,000 miles. As far as I can tell, it is stock and I've put about 3000 miles on it. New sparkplugs and the old ones looked good.
I have a power drop when accelerating WOT. The only thing I've noticed that happens along with the power drop is a loud "sshhhh" noise coming from the exhaust. I mean, if you ever shushed someone, it is an extremely accurate representation. It could be coming from in the exhaust or it might just be it resonating. I believe that its more likely the former since it sounds like its coming from the muffler.
If the car is started and it does it once, it'll usually do it for the rest of the time the car is on. If the car is started and it doesn't do it, it'll drive excellent for the rest of the time. I believe the diverter valve is also louder when the car is working correctly.
I now have a Cobb Accessport. My first instinct is that it is an issue with boost/wastegate. However, on the stock tune, I get ~19 psi. On a stage 1 Dizzy 93/E30 tune, I get ~24.50 psi. On the stock/E30 tune, there are only positive ignition corrections and the 93 only has occasional negative corrections that quickly recover.
I looked at the intercooler hoses during my last oil change, and they all seem to be on tight.
What do you think I should monitor or look for?
S
sczamun
Indianapolis
Thread Starter #2
I would also like to add that by powerdrop, I mean it still accelerates. Just feels gutless.
S
sczamun
Indianapolis
Update: replaced diverter valve with a GFB+ and OEM (Pierburg) boost solenoid. Replaced the first because it was sticky during inspection and the second when I accidently bumped the solenoid, breaking off the tiny barb going to a vacuum line.
It didn't address the issue, but improved just about everything when the car works. Boost is now at 25.7 psi vs the ~24 before, even when exhibiting issues.
At this point, I believe the wastegate is intermittently not closing properly leaving a small leak, either due to the wastegate actuator or something else. I will pull the turbo to inspect and give the exhaust one last check. I have a good, used turbo and may just replace it altogether.
Pittsburgh
Yeah it’s a boost leak. You’re on the right track. If it was a hose it would be a pop and then a shush. Sounds like a valve being slow.
Indianapolis, IN, USA
Any updates on this? I may have a similar turbo issue
S
sczamun
Indianapolis
Not yet, it's been busy for me lately and I haven't had much of a chance to do a more thorough inspection from the exhaust manifold and back. I'll definitely keep this thread updated, but it may be another few weeks.
