Boost flactuates at high rpm
Malta
Hi everyone,
I am currently tuning the car with an S280 turbo, and when increasing boost, I am experiencing oscillations above 6K rpm.
Wastegate duty cycle is not maxed out yet. Has anyone experienced this and what would be the cause please ?
Thank you
https://datazap.me/u/eas/run-high-boost?log=0&data=1-3
Mods as follows:
S280 Turbo with s280actuator
Ported manifold
3.5" decat and cat back exhaust
2.75" Crossover with ITG Intake
South Africa
Might be late, but it is worth checking your spark plugs and coil packs. If they are worn, they can cause boost dips by misfiring when under pressure.
S
Malta
A very weak actuator spring was causing this. Changed to a different actuator and problem solved.
