Audible Pinging - Negative timing corrections
Santa Barbara, CA
Trying to sort out a very annoying issue on my 2015 that has been frustrating me for a few weeks.
Bought the car all stock, 57k miles. It had a new slave, trans fluid, and clutch put in at 53k miles at the dealer so felt like a decent buy. Did the usual new vehicle to me program of oil, filter, sparkplugs (iridium) etc. Drove just fine.
Out of curiosity I wanted to uncork it and get a Cobb. Ran fine on Stage 1. Got the itch for stage 2 and did intercooler (Mountune), and Koyo rad. Ran fine again. Timing belt has already been done. Car has 67k miles now.
Popped on a stage 2 tune (at this time, who it is doesn't matter, the issue is with my car), and was quite pleased with it. I noticed a weird kazoo noise in the cabin and figured the symposer was leaking, so I deleted that with a Whoosh plug. That's when the issues started or maybe they'd been there the whole time, but the symposer cabin noise was covering them up. I heard noticeable pinging from the car under load, still pulled fine, but I thought eh, maybe it's a boost leak. Cut the hose shorter on both ends, put on a new clamp on both sides. Still there. Replaced plugs with pre-gapped to .028 ruthenium from Tunewerks. Still pinging. I did send the tune to the tuner, who said it didn't look good and suggested bad gas. I've run 5 tanks through it, all from busy stations, a mix of Shell, 76, and Chevron - same result across all brands.
To start, yes, I have read the article from Stratified about negative timing corrections. I've been seeing a very regular -3, even -4 on all 4 cylinders and the tune just feels sluggish, it's pulling timing the entire pull and you can audibly hear pinging from the engine. Even taking the car back to Stage 1 Cobb, I am hearing pinging. It seems crazy to me to have to go back to stock after all this.
Where should I look at next to try to try to cure this issue? I am at wits end.
K
Santa Barbara, CA
What's your current octane adjust ratio (OAR) on the accessport?
I have not been able to get it to -1.00. It seems to float around -.65 to -.80.
On the iridium I was not getting any misfires. I got a bunch of them with the Ruthenium after install, and the pulled timing is even worse now. After seeing that, I put it back to stage 1 again while I sort out these issues. I ordered some coils from Whoosh, which I have not yet installed, but I can't really imagine that all 4 OEM coilpacks would go bad at the same time, shy of 70k miles.
I did also check my fuel pressure just in case, and requested fp and actual is lining up nicely.
K
Santa Barbara, CA
I replaced the plugs with Ruthenium, and the coil packs with Whoosh (I know they're not universally loved, but for the price was worth trying), loaded up the Stage 2 and very carefully got the OAR down to -1.00. The tuner recommended I add 1-2g of e85, which I did, and the pinging disappeared. I have since ran through that tank and am waiting to see if the change is permanent. I still hear a touch of pinging, but it is much improved from before.
I think it may have been the OAR not being optimized?
K
Santa Barbara, CA
It is back to pinging again now that the E85 has been run out of the tank. Sigh. This really makes me bummed on the car, honestly. I am at a loss with what to do functionally to improve it.
It's Dizzy. This said, I am also having issues with Stage 1 OTS Cobb having high negative corrections and pinging, so I don't think this is an issue with his tuning. He has been communicative and said there are issues with the datalogs and I am waiting to hear back from him about what's next.
Does it happen on the OEM tune also?
Grsemky
U.S. Navy Veteran
Arizona
I'm on dizzy stage 2, I live in AZ so I get the same shitty gas but my OAR is consistently at -1... Chevron dropped mine down to -.9 but nothing terrible, I'm curious why you're is so low without adding E85
