SourSkittles has not been active on this forum for over 6 months now and his Cyborg / C39 turbo (which was found to have faulty seals) is not available....
DHM who was also selling these turbos declared bankruptcy and is out of business...
As such this thread is now closed....
**Pricing and options have been updated and upgraded**
The second option is the new Cyborg39. SCRATCH THAT !! The results from the Cyborg39 have been so impressive that we now only offer 1 cyborg option.
We send the turbo through the same process as the original cyborg upgrade. Only with this version, we machine the turbine housing out to accept a larger turbine wheel that has been clipped the same way we clip our factory turbines for increased flow. The extra large stainless inlet is also included with turbo as its required.
$1475 shipped with only a $250 core charge.
~~~~We still have many options to suit budgets, needs and goals. ~~~~
We now have moved to a 19psi base EFR wastegate on both turbo charger options. And it still have the great price as before. $100 with either cyborg option. *Must be purchased with a cyborg turbo at the time it's being built.
****We now have two port-work options****
To help budgets while making it more affordable to ensure your getting as much performance for your money as you can I've decided to offer a basic port job. Enlarges the parts of the system that are the most restrictive. No more. No less.
$200 and add $75 to your core charge.
We still offer the same full port job that many have gotten over the last 2 years. Many can vouch for the work, and it still takes me 12 real labor hours on each turbine/manifold pair. Removing the wastegate arm and fully porting the wastegate hole is part of this as well as polishing the runners. A port matched manifold gasket is now included for free with this service.
$350 and add $75 to your core charge.
****Now we offer two thermal control paths****
Complete heat wrap and turbo blanket installed and ready to use. $150.
And now we are doing "turbo X" manifold and turbine coatings as well. Turbo LSx guys love this stuff and we have had good results using it on Cummings setups. $200
Stock turbine housing
Cyborg39 turbine housing.
http://youtu.be/6sl9CW-WGvk
http://youtu.be/2KZ8bl3rAnA
Reviews
EWG Cyborg Version1 Turbo Review
http://www.fiestastforum.com/forum/showthread.php?t=7591
Cyborg Turbo Review
http://www.fiestastforum.com/forum/showthread.php?t=7575
Reviews
Cyborg Turbo Review
