Shorty or Shark Fin?
Los Angeles
Having trouble deciding.
The shorty seems cheap and simple.
Shark fin just looks good.
Decisions, decisions
rooSTer
Miami
The shorty is an easier swap. Some shark fin requires removing the base which can end up messing up your headliner.
U.S. Navy Veteran
SFV, So.Cal.
Is there a certain shark fin in mind?
Is there a shark fin that is OE on another Ford that might connect in correctly?
Dave
rooSTer
Miami
MK3 Focus stick on shark fin should work..just search on eBay.
Connor
Los Angeles
The shark fin I was looking at is from Visual Garage. But I didn't think about an OEM one.
U.S. Navy Veteran
SFV, So.Cal.
I was just thinking that the quality of an OEM unit may be better than aftermarket.
The draw back however is that it may also be more expensive.
In this case, I would go for the quality.
This is why I was hoping for a Ford car that had one as original equipment.
Dave
FocusMike
Dearborn
I saw the Visual Garage antenna cover before and to me it makes the most sense. The only thing holding me back is that it looks a little bit too large since he has to cover the stock antenna base.
Los Angeles
I apologize in advance for reviving this old thread. New FiST owner here. Would a S2000 antenna be a simple screw on as an antenna option? Thanks.
Los Angeles
I don't know if the threads are the same between the Honda and Ford antenna. The threads are the same for the Ford and Subaru though. I went with the Perrin 4" shorty and I haven't noticed any reception issues.
http://www.rallysportdirect.com/par...bdy-122-perrin-shorty-antenna-4in-w-sat-radio
The Perrin antenna works for the Evo IX, which I had a S2000 antenna on. So you've just answered my question. Thank you! :)
