Fumoto Valve?
Spring, TX
Anyone using a Fumoto valve on their FiST?
I have one on our Expedition & it dramatically makes oil changes a lot easier.
Couldn't put one on the Cooper, as the drain plug was vertical on the bottom of the pan & the Fumoto would've stuck out too far. A right place/wrong time piece of debris, or an extra tall speed bump would've taken it out.
Haven't been under the FiST yet to see how the oil pan setup is & if it would be conducive to swapping in the Fumoto on the first oil change.
Anyone have a shot of the underside/oil pan area, or can confirm one will work well in the FiST?
JAMADOR
Spring, TX
Excellent!
Will get one ordered before I do the first oil change. Makes it so much easier.
