1st ever dyno session
Complete novice so bare with me. The 1st 3 runs that was done i was told there was a misfire, so the spark plugs were changed and the old ones had to much gap in them I was told so we put a new set in.
This is the test results before plugs were changed.
F
Thread Starter #2
And these are the results after the new plugs were in and another run on the dyno thr guy said its better than before
F
Are the last results okay with new spark plugs
I don't see a lot of difference between tests 2 & 3 and then test 7 with the new plugs. It would also be helpful to note any Mods or Tunes. Because Tunes can build a lot of power. I will also note that going too far with a Tune can end up with needing a new engine.
F
Not planning on tuning it just wanted to see what it looked like. What are them small dips on the graph lines please i aint got a clue?
