(Possibly) Blew a head gasket looking for suggestions
Following SP63s requirements:
0-150 miles - Motul 10w-40 break in oil
150-300 miles - conventional 10w-40 (I got castrol, but any decent conventional is fine)
300-500 miles and 500-1000 - conventional again (and again)
1000+ and in perpetuity - Amsoil extended life 100% synthetic 10w-40
Did SP63 purposely build it with clearances to handle a 10W-40 oil, or is that what they suggest anticipating the proposed cylinder pressures with your setup under increased boost and an aggressive tune (or some combo of the two)?
CHAPEL HILL, NC, USA
I was also wondering why you're using 10W-40 oil.
arlisscm
Clyde
Thread Starter #103
10W-40 is the requirement from SP63 as that is what the bearing clearances are set up for.
As you mentioned, my guess would be it is for higher load capacity to handle higher cylinder pressures, bearing loads, etc.
Since the engine durability is rated for 550-600HP, it is built with a lot more stress in mind than what it is going to see. For now....
arlisscm
Clyde
Thread Starter #104
Using my commute to contribute to the break in miles (only ~36 miles a day, but adding extra by just driving around more on my way home), looking to hit the 500 mark tomorrow to do oil change #3. Then get to the full 1K by the end of the weekend to get it all done and sorted. Dyno/tuning session still scheduled for May 11th as of right now.
Scope of the rebuild continues to creep, just pulled the trigger on a Paragon/Alcon front BBK to replace my Wilwood setup. Wilwood setup has worked fine, I just go through pads/rotors so fast, so I want something more track focused and beefy to hopefully get more time out of the consumables. Lead time is 4 weeks, so I may or may not have them on for my first set of track days May 30 and 31. Ordered a new set of front pads for the Wilwoods just in case the new setup hasn't arrived yet.
