- Member ID
- #4150
- Messages
- 14,616
- Likes
- 7,122
I like the 15x8 also and I'm thinking about lowering too but I'm just curious why you would choose this tire size vs a 195/55 15?
Also, once you move away from the BFG SC2s in 195/55-15s, you get a ridiculously narrow tread width in that size, although it is somewhat made up for by the much stickier compounds of those other tires.
The major disadvantage of the 225/45s is their much lower overall gear ratio due to being so much shorter than the OEM overall diameter, even though Rick (RAAMaudio), and others on here would disagree about this (but most of them are on BT kits which could benefit from a 'steeper' effective final drive, which the shorter tires give them, in order to get spooled that much quicker).
It also just LOOKS better than even the wider than most 195/55s BFG SC2s.
![Wink [wink] [wink]](/images/smilies/wink.gif)
