2014 fiesta st
Txman67
Military Veteran
Montana
The clutch pedal has play in it,the clutch is working fine the only issue is the play in the pedal. The car has 83000 miles on it and i believe the clutch hasn't ever been changed any ideas what is happening?
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
You're posting this in the new member intro section. Might do better in a tech section, but this thread would be a good opportunity to introduce yourself to the folks on the forum.
And just a heads-up your description of "play" is going to be very subjective. It's not likely to get a lot of responses because there's almost no info to work with. Every clutch I've ever used has what I would describe as "play" if it's working fine I probably wouldnt' worry about it.
Burlington, NC, USA
Bleed the clutch and see if that helps. This car is known to have a slave cylinder that’s prone to failure.
