2016 fiesta st
Help guys
My 2016 fiesta st bugs out when i accelarate
Codes are P193F, P219A and PO454
Anybody had this codes fix could tell me what to do
Thsnks
A
Thread Starter #2
Help guys
Thsnks
When does this happen? After you get gas/ re-fueling
Evaporative control solenoid* possibly
A
Sorry for the late response it only happens when i hit the gas to pass a car or if i want to go faster
anthony,did you ever fix the problem with the check engine light and code PO454? i had a cobb stage 1 and everything was fine.two weeks after putting a stratified flash tune in i am getting code PO454.did you have a tune in your car?
I’ve had a pesky p219a code ongoing since about 1hr after buying my car in January. She had one prior owner and I am uncetain I have slight lag that seems to manifest around 1,800rpm but goes away. I am stage 1 COBB ots right now.
currently I have replaced:
1. evap purge valve
2. PCV valve
3. Ran crc intake valve and turbo cleaner
next up I am replacing:
1. Injectors
2. Upstream O2 sensor
3. Downstream O2
things have gradually got better with my “fixes” I’ve done as far as Ign Corr and overall car response. There are a few p219a threads out here on the forums I’d look into for that. P0454 appears to be EVAP related like what Typhoon mentioned
