Tire place said they couldn't mount a 245/45-16 r888r on a 16x8 rpf1. I know it's wide.but I'm surprised. Not that they wouldn't but they couldn't, it was "floating around on the wheel" - anyone have any thoughts?
That’s super weird, it varies by tire and manufacturer, but the Toyo published specs both on their website list 7.5-9.0” width range, with 8.0” as the standard “measured width” which is the mounting they use to determine the other specs (tread and section width, diameter) which change depending on the rim mounting.
Take the Toyo or Tire Rack spec sheet to them and show it to them. 8.0” is not just in the range, it’s standard fitment for R888Rs in that size, and the tire shop is way off. Tell them you want normal mounting, not hellaflush stretched tires.
Did they actually say it’s too wide, or just that they couldn’t get them to seat on the bead? They’re probably just complaining because R888Rs in all sizes are fairly stiff XL tires which like runflat tires are usually a pain to mount and seat compared with SL standard load tires.
https://www.toyotires.com/product/proxes-r888r/
https://www.tirerack.com/tires/tire...WR6R888R&vehicleSearch=false&fromCompare1=yes
Otherwise, find a new tire shop.
