35mm lowering springs and spacers.
Essex
Hi there, I hope all is well. I wondered if anyone could help please. I recently purchased a MK7 2017 ST3. I’d like to lower it on H&R 35mm lowering springs with 20mm spacers at the rear tires and 15mm at the front. It’s running its stock 17” alloys and tires.
Does anyone know if there would be any issues with rubbing with this set up?
Many thanks.
Grsemky
Arizona
Many thanks.
I have super sports, which should be the 35mm, no spacers and stock wheel size, I only rub at full lock with compression... It's mostly on the bumper tab on the inside of the well, you can shave it down to prevent most of it
