Adapters to convert to 4 x 100 bolt pattern
West Barnstable
I know you can drill the rotors to convert to 4 x 100 pattern but was wondering if you could do this with adapters and run Enkei RPF1 16x8 4x100 wheels. Having the adapters would make it easier to revert back to say, use current winter wheel/tire combination. I have seen adapters available https://www.uswheeladapters.com/shop/1-4x4-25-4x100-wheel-adapter/
J
West Barnstable
I was wondering about this. It might work if it was about 15mm but I think most are much thicker than that.
jeffreylyon
Pittsburgh
There a set of 25mm spacer/adaptors on the classified forum now. I drilled my hubs. Not too hard, *much* lighter and I don't have to worry about the clearance issues 25mm less ET is gonna cause.
