Anyone able to help me out with install times for part
united Kingdom
Hey guys
Trying out a new garage soon and wanted to know how long parts took to install
New radiator. The front bumper will already be off and so will the inter cooler
My guess 30 minutes
Turbo smart plumb back bov. The turbo will already be removed
My guess 5 minute
Upgraded rmm. The previous one was installed a year ago
My guess 10 minute
Please help as not looking to get ripped off
Thank you
Burlington, NC, USA
Radiator - will you have the crash bar off as well? Will coolant be drained already? I'd expect at least an hour or two if they have to finagle around the crash bar, drain the coolant, install radiator, refill and bleed coolant, then reinstall the crash bar. If the crash bar is off and coolant drained, 30 min. may be enough time but I'd expect to be quoted an hour at the bare minimum. It took me 6 hours to do on the garage floor by myself.
Don't pay someone to install the BOV if you already have the turbo out (assuming it's a stock or stock frame turbo). It's literally 3 screws and takes 5 min if you use one hand and blindfold yourself. Add another 5-10 min. to install the MAP adapter and vacuum line if it's a mechanical BOV.
RMM probably 30 min. if they've never done one before. Maybe an hour.
Don't be surprised if shops won't quote you less than 1 hour increments.
L
united Kingdom
Don't pay someone to install the BOV if you already have the turbo out (assuming it's a stock or stock frame turbo). It's literally 3 screws and takes 5 min if you use one hand and blindfold yourself. Add another 5-10 min. to install the MAP adapter and vacuum line unless if it's a mechanical BOV.
Thank you so much buddy
Appreciate that
