- Member ID
- #4150
- Messages
- 14,718
- Likes
- 7,194
Is there any way to tell if a factory front damper is bad/going bad, other than taking it off and dyno-ing it, or doing the totally inaccurate 'corner push' test thing?
There are NO visible external leaks anywhere, but it did take some HUGE, bottoming out/crashing into the bump stops type hits on some ARA rally stage roads I was working on last year.
This is the passenger side front, and I question it because the 205/50-16 Neo Gens on Dekagrams rubs badly on just that side (which took those hits as well), but only at high steering input angles, while braking at the same time, at low speeds (like pulling into a parking spot), but also when backing out even at low speeds with the same steering angles it makes a loud 'creaking' scraping sound.
Granted, the Neo Gens are overly wide in both tread width and section width in that size, and then they are stretched even wider by the 8" wide wheels, but why only on that side do they rub?? (WHY I suspect a blown out damper.
I have yet to check the factory sway bar end links, but IF they were the culprit, wouldn't there be problems/loud noises ALL of the time, especially during higher speed, high g turns?
I am afraid to even think about putting the 225/45-16 A052s with Dekas on the car at this point.![Frown [:(] [:(]](/images/smilies/frown.png)
![Wink [wink] [wink]](/images/smilies/wink.gif)
![Really Confused [???:)] [???:)]](/images/smilies/confused.gif)
