- Member ID
- #2549
- Messages
- 65
- Likes
- 19
I installed my Bilstein Coilovers yesterday (standard Fiesta set, part# 47-167490). The fronts at the factory setting just barely had the smallest amount of preload on the springs. I had to raise the front anyway due to having taller 205/45r17 tires, but at the factory setting I was concerned the springs would be too loose at full droop. For the rear, I have the adjusters almost all the way lowered (~5 threads left above the collar) just to remove most of the rake compared to the front after adjusting the front up to stop the massive rub I was getting.
For those of you with these coilovers, what kind of height adjustments have you made?
