FYI...
http://www.boombaracing.com/2014-fiesta-st-brake-cooling-deflector/
MSRP $135
Sick and tired of experiencing brake fade and a mushy pedal? Boomba Racing has the solution for you! The Boomba Racing brake cooling deflector kit for the Fiesta ST helps to channel air towards your caliper and rotor when driving. The cooling deflector mounts securely to the A-arm using a hole that is already there for a completely reversible installation. Ground clearance is not compromised and there is no need to remove your fog lights or drill any holes. This kit can be installed easily in your driveway using a jack and jackstands.
If you look at the data above you can see that we had noticeable drops in temperatures after the installation of these deflectors.
Removal of the rotor dust shield is highly recommended in aiding air flow to the brakes.
The deflectors and mounting brackets are made from aircraft grade billet aluminum and feature all stainless hardware. These pieces are available in your choice of four different colors: natural finish, blue, red, or black anodized.
[HR][/HR]
Demonstration Video (below) Installed on FoST
Published on Dec 17, 2015
"This video demonstrates the differences in what happens with airflow when the deflectors are not in place vs. what happens when you install the Boomba Deflectors. As you can clearly see in the video, with the deflectors installed the air is channeled into the wheel where it can work to cool your braking system. This was proven with constant temperature drops throughout testing."
https://www.youtube.com/watch?v=O-Z8lFB1WJI
[video=youtube;O-Z8lFB1WJI]https://www.youtube.com/watch?v=O-Z8lFB1WJI[/video]
MSRP $135
[HR][/HR]
