Boomba Transmission Bracket Bushings Install...
Went ahead and got the Black Boomba Racing solid shifter bracket bushings (for the shifter cable plate on the transmission.
Did the Install today and love the feel afterward it is just a tad crisper and more defined when selecting a gear . I also have the Mountune quick shift so your results may be different..
Here are some pics
Most of the Tools needed
Engine cover removed check
Air Intake tube and Airbox removed check
There is what i need to get to the shifter cable
Battery out Check and what you need to remove the battery box and attached ECU
At THIS POINT SOME HAVE REPORTED Getting the bushings replaced without taking the cables off or the braket out. That works too this is but one way to do it
Then just put everything you took off back on in the order you removed it and have fun
Very nice feel once it is done
Have had this upgrade in for a while and LOVE IT one of the best cost effective MODS you can do...
Kudo's Boomba!!
They provide very good instructions along with a great Product..
Here we see the Blue bushings also
Here are some pics
Kudo's Boomba!!
