Hey all, once I decided I wanted to install the boost gauge I had gotten for free when I bought some parts for my FiST, I realized the A pillar mount from ProClips would cause the AP’s cable to block the gauge so that had to be addressed. I didn’t want to install the boost gauge for its functionality, instead I just wanted a project. 😂
Thanks to @woodford86 I was previously able to route the AP cable through the right driver’s side vent (I’m considering writing up a how-to on how to do it). I used a magnetic phone mount compliments of the magnetic back of the AP. It’s a better placement and allows me to more easily see the AP’s gauges and I can now use the shift lights which I hadn’t been able to before.
That led me to installing a Whoosh Boost Tap care of @Jabbit. I had to use the Turbosmart hose which made it difficult to get onto the boost tap. Hot water didn’t do the trick so I used a lighter and gently heated up the hose end. It’s a little ugly now but does what it needs to without issue. I stupidly forgot to route the hose under the induction hose but oh well. The boost gauge does its job in its Whoosh vent adapter.
Happy with the results. I highly recommend the cable routed through the vent for the AP even if you don’t install a boost or ethanol gauge. It’s simply a better view.
