BOV Install Failed
Truth in Ruin
Lincoln
Jacked up the front passenger side correctly; took the tire off, and discovered that I couldn't reach, or get-on the front bolt. Said screw it, I'll have my mechanic do it on a lift.
While the car was jacked up, I noticed my rear passenger side tire was also off the ground. After putting the car back down- I noticed both wheel gaps on the passenger side were gapped much greater than the driver's side. Is this from the springs being depressed? I've never experienced this before, so if anyone has a correct answer for this, I'm all ears. Thank you.
Charles Town
This is normal. Drive it around and it will go back.
Butterybunz
Minneapolis
Yes, that's normal. When you let out the e-brake the suspension will settle back to normal.
You need an extension and wobble end to easily remove the stock BPV.
T
Truth in Ruin
Lincoln
Thanks for the reply. I was just using a long straight one (that doesn't sound good). Still was unable to get the round end on the dang screw.
