CLOSED: Cyborg TurboCharger * NOT AVAILABLE *
Status
Not open for further replies.
jayrod1980
All this talk makes me want a cyborg set up even more. Maybe by the end of the year if one can still be built!
DHM1
Do it! I have a core to ship out if you need it you can come to the shop for the install and tune!
Russ
DHM1
Appreciate it Russ and love your work but Michigan is a long drive from Vegas!
Haha oops must have got your screen name mixed up. There is a jay something from IL that come to the shop for installs lol
Russ
Mr. Sour,
You sure you don't want me to tune that hog?
Cyborg, EWG, Full Bolt Ons, Stock Fuel System, No Meth, E40.
Hey Adam,
Any chance I'd see an improvement running E40 instead of E30 on my car? I just finished installing my Mishimoto Radiator, and coupled with the Oil cooler, I'm gonna be tracking the piss out of it this spring and summer.
Sourskittle
Sourskittle
Thread Starter #1,107
Cyborg upgraded stock Turbocharger system
Ok... Time to let this cat out the bag :D
This is mine :)
I'm waiting on a special tool that lines the cams up to the timing belt gears since it doesn't have a key-way or groove or timing marks !!!
Exciting stuffs
[MENTION=1098]DHM[/MENTION]
jayrod1980
What is the benefit of the Garrett IC core? Are you going to weld it yourself?
Sourskittle
Sourskittle
Thread Starter #1,110
I'm going to let Russ handle any questions about the garrett vs non-garrett stuff. I just knew I didn't want anymore excuses for me.
I also figured, no freaking way I'd ever find myself in a spot where I could afford the DHM big intercooler kit again, so doing it once and never second guessing it again was the only way forward for me. I also recommend that others think about that before buy ANY DIRECT FIT. You could spend $400-$700 and in the end, end up buying a 2nd intercooler for slightly more money AGAIN. Don't something I could afford to do twice. Weather the garrett means a lot TO US or not, IDK. But on higher hp cars, it def matters, and by nature, the cyborg is hard on a cooler. I wanted max cooling ( frontal area ) and great flow.
I've def having russ do the fab work/welding :)
Also just got word Mistu shipped my cold pipe 6 weeks ahead of schedule, so that was a nice surprise.
Once the cylinder head is check/decked flat, I'll be ready to roll.
Hijinx
To echo Sour, I'm on my third cooler (Russ') and $1700 spent. But, we didn't have the options we do now... At this point in the game, you can do everything right the first time without having to experiment.
jayrod1980
Ha, I purchased the DHM race IC and bar before I even took delivery of the car. One mod I have zero regrets with.
TempeST
OOOOO!!! I can't wait to get mine!!
Congrats on the purchase and I'm sure you will see a little difference. you gonna drill out your grill as well? I will do that the same time I install mine. even thought about opening the front bumper up a little too, but we will see how it performs with open grill and no bumper cuts first.
jayrod1980
Just melt the crap out of it with a sander or angle grinder and flap disk. Once you get the hang of it, the work is fast. Just takes some fortitude to get over the appearance in the beginning of the plastic melting. Whatever you haven't ground will be a different composition allowing you to easily separate the melted slag and the intact grill underneath. It will likely still take some razor blade work of you are a perfectionist like me.
jayrod1980
Also, I did some WOT pulls this morning at 60 degrees. At vacuum the charge temps sat around 2-3 degrees above ambient. Extended WOT would sit at ambient, and upon return to vacuum (off the gas completely) my temps would briefly drop below ambient. Perhaps a condenser effect like with an A/C? Regardless, I don't think you can cook this IC. I'm more worried about the garbage oil and water cooling in the vehicle.
I finally installed the WRC vents. Two things I've noticed right away: 1 - driving hard through the mountains around here I couldn't get below 20 degrees over ambient, now I'm within 10. 2 - the coast down is a lot slower (I roll further in neutral).
Siestarider
Longer coastdown = improved aero. Surprise to me. Maybe filling those low pressure areas on top with hood vents reduces turbulence along sides of car? When I ran pressure tests on underside of hood, not one was positive. But the overall engine compartment tends to show air pressures drop about -.3" going from underside of hood to underside of chassis.
So your engine compartment should now show more even pressures from underside of hood down to bottom of chassis if theory applies.
I just ordered the 2J and maf extension, [MENTION=952]frankiefiesta[/MENTION] can you take a pic of how tight the fit is with the EWG?
Status
