Creaky driver side fender/headlight
jayrod1980
So as background, I have the DHM crashbar, which has slots for the headlight retainers (those white clips the headlight snaps into). Also, my body panels at the fender/bumper line have never been perfect alignment wise.
My issue is that the driver's side headlight lightly touches the bumper/fender where the bumper and fender come together. This causes the car to creak and squeak when I turn, etc. I've tried loosening the crashbar and realigning it as well as adjusting the headlight. I also attempted to bend the section the bumper bolts into slightly to get the panel to have a tight, uniform gap.
I can't see any real way to fix it. I'm next going to buy two new retaining clips, as one is loose in its gap in the crash bar and the other I broke a piece when reseating it (passenger side, but no issues there).
Anyone else experience this issue, or have any tips? The creak is driving me crazy.
Hmmm...spray it with fluid film....get it at alot of parts stores napa....oreallys.....autozone I know has it. See if that helps. Good luck
J
jayrod1980
Is this silicone spray? I wish I could raise the headlight clip. I'm sure I just need to lift the crash bar more but it drives me crazy!
Smitty
I had same problem on my 2015 st and sprayed one squirt of WD40 in between fender and front clip and stopped all creaks at the bottom of the headlight.
