Dave's 2014 OW build
#41
Those Grids are really nice...! Did you throw them on stock tires?
Kip2MyLou
#44
Car looks awesome man. Love the gold and white look. Want to go gold with my black st but I think they would take so much to keep clean.
J2FoRS
#48
Do you lose that vent entirely? Or does air still flow around the gauge you just can't choose where the air goes?
Sirsinclair
Thread Starter #49
Awesome car! Sub'd.
Thanks guys!
And can you post another picture of your AP set up? I like where you have that positioned.
Yeah, I'll take a couple of pictures when I get a chance.
Yeah, the air still flows just can't change the direction.
#50
I love the dash setup it looks mint! my question is where did you tie into the manifold to run the line for the gauge? i know it needs to T-off one of the lines, im just looking for the easiest way
Sirsinclair
Thread Starter #51
Mine is ran off the vacuum block that came with my Turbosmart BOV.
#52
I must've missed that post about the turbosmart, i looked at that and i love that it has the additional parts but i stumbled across the boomba adapter and i think im going to start with that for now until i upgrade the rest of the car and then upgrade the BOV.i think im going to T off the vacuum line in the center of the intake and run it that way. i love the wheels too white and gold looks sick!
Sirsinclair
Thread Starter #53
Thanks man! Good luck with your install. [wrenchin]
#54
Are you running wheel spacers?? Or is that just the offset of the rims that make it stick out further? Siiick ride btw
Sirsinclair
Thread Starter #55
No spacers, it's the wheel offset. Thank you!
#56
Looking excellent. As of now my favorite OW build I've seen. Definitely an inspiration to a fellow OW owner.
#57
Question on your wheel setup, any rubbing? And what tire size do you have on it I noticed they are 8" wheels
Sirsinclair
Thread Starter #59
Thanks guys!
Yes, there is a small amount of rubbing under aggressive/high-speed handling. I'm running the stock 205 tire; I fear that there will be more rubbing if I go wider. The offset is too aggressive. I will address this problem in the future with either a new set of wheels, or some type of wide body/fender flare.
#60
What offset do you think would be good for a 17x8 wheel and not rub? I really would like to go 17x8, but I may just go to 17x7.5 to play it safe.
