Details on COBB Economy tuning strategy?
iso100
I'm running this map until the spring time when I remove the winter tires and install the summer ones again.
Does anyone have technical details on what they did to squeeze out more efficiency over the pseudo economy map found in the "stage" maps via on-the-fly switching?
DHM1
Royal Oak
From what i seen it seems boost curve and boost ramp has been changed along with some lambda values. There is plenty more room for improvement with a pro tune.
Russ
Grand Rapids
I don't know what they did to get the real economy map, but the pseudo economy map (slot 2 on the v200 stock maps) is just a 0% Wastegate Duty Cycle across the board (wastegate always open)
BoostBumps
Arizona
Only two key areas are changed when using either "Economy" and "Pseudo Economy" (Slot #2) modes ...And both ECO maps use similar strategies...
1) "Desired Fuel Target" values are slightly leaned out by roughly 0.2~0.3
2) "WGDC Boost by Gear Multiplier" and "WGDC Base" values are all set to "0"
"A setting of 0 will eliminate WGDC at a given throttle position in the desired gear".
